February 14, 2026
When and Why You Should Use Emergency Dental Services
A dental emergency can strike at any time, and when it does, it’s important to know how to handle the situation. Emergency dental services are designed to provide urgent dental care when you need it most. Here are some reasons why you might need to use an emergency dentist in Ottawa and what you should do if you find yourself in need of urgent dental care.
When to Use Emergency Dental Services
There are many situations where you may need emergency dental services. Some of the most common dental emergencies include:
  1. Severe toothache. A severe toothache can be caused by a number of different things, including an abscessed tooth, a cracked tooth, or a deep cavity. If you are experiencing severe tooth pain that does not go away with over-the-counter pain medication, you should seek emergency dental care.
  2. Broken or avulsed tooth. If you have a broken or avulsed tooth, it is important to seek emergency dental care right away. Depending on the severity of the damage, your dentist may be able to save the tooth if you act quickly.
  3. Loose or lost filling. If you have a loose or lost filling, it can cause significant pain and sensitivity. Additionally, if you do not seek prompt dental care, the affected tooth may be vulnerable to further damage or infection.
  4. Abscessed tooth. An abscessed tooth is a serious dental infection that can cause severe pain and swelling. If you suspect that you have an abscessed tooth, you should seek emergency dental care immediately.
  5. Broken or damaged orthodontic appliances. If you wear braces or other orthodontic appliances and they become broken or damaged, it can cause discomfort and may also interfere with the effectiveness of the treatment. In some cases, the appliance may need to be repaired or replaced in order to continue treatment.
There are several reasons why you should use emergency dental services when you experience a dental emergency. First and foremost, emergency dental services provide you with access to urgent dental care when you need it most. This can help to alleviate pain, reduce the risk of infection, and prevent further damage to your teeth and gums.
In addition to providing urgent care, emergency dental services also offer a range of treatment options to address a variety of dental problems. For example, if you have a broken or damaged tooth, dental fillings, crowns, or other restoration methods can be used to repair it. Alternatively, if you have an abscessed tooth, your dentist may need to perform a root canal to remove the infection and restore tooth health.
Finally, emergency dental services can help prevent dental emergencies from occurring in the first place. Your dentist can provide you with tips and advice on how to maintain good oral hygiene, prevent tooth decay and gum disease, and reduce your risk of dental emergencies in the future.
What to Do in a Dental Emergency
If you experience any kind of dental trauma, it’s important to act quickly. Here are three things you should do if you find yourself in need of emergency dental care:
  1. Contact your dentist. If you have a regular dentist, contact their office as soon as possible to schedule an emergency appointment. If your dental office is closed, they may have an after-hours emergency number you can call.
  2. Explain your situation. When you speak with your dentist, be sure to explain your situation in detail. This will help them determine the best course of action and ensure that you receive the appropriate treatment.
  3. Follow your dentist’s instructions. Your dentist will provide you with instructions on what to do before your appointment, such as taking pain medication or applying a cold compress to the affected area. It’s important to follow these instructions carefully.
If you experience any of these dental emergencies, it is important to seek immediate care from an emergency dentist in Ottawa. Delaying treatment can lead to further complications and more serious dental problems. Visit Family Dental Care today!
