January 31, 2026
What Is Invisalign, and What Is Its Use? Getting to Know Its 4 Types
Overbite, crossbite, overcrowding, spacing, and crooked teeth are common orthodontic problems that most people face. Fortunately, various orthodontic treatments are available in the dental industry to solve these problems. One of these treatments and solutions is Invisalign. Invisalign clear plates are a part of invisible orthodontics. Invisalign is a modern and contemporary alternative to conventional metal braces.
According to a dentist performing Invisalign in Toronto at Fort York Dentist, a set of Invisalign and translucent orthodontic plaques are created depending on the type and severity of the patient’s condition using special computer software to replicate the state of the patient’s teeth. This orthodontic method is made of thermoplastic and practically invisible materials. At Dentistrynearme, which is a successful and trusted dental directory in Toronto, Fort York Dentist has been introduced as a great dental clinic with the most successful and experienced dentist in Toronto.
Types of Invisalign in Orthodontics
When you first hear the name Invisalign, you might think that they are just a transparent plaque, and when it is placed on the teeth, it will solve all the problems. But this idea is different. There are different types of these transparent plaques, each of which is used to solve a specific orthodontic problem.
1. Invisalign Express for minor cases and mild problems
Express Invisalign offers a shorter treatment time compared to other orthodontic treatment methods. This transparent plate is a good choice for people with a small gap between their teeth or minor crowding.
This type of transparent plate is a good option for people who need to perform restorative procedures such as dental veneers, composite bonding, and dental laminates but also partially straighten their teeth.
2. Invisalign i7 for minor and mild problems
Invisalign i7 is another member of the Invisalign family that corrects minor abnormalities, such as gaps between teeth or small gaps between teeth. This item is primarily cosmetic and used for a short time.
These clear or invisible plaques are often used to straighten and correct problems with front teeth, although they can also sometimes straighten back and side teeth. But they mostly work well on the front teeth. The duration of orthodontics with this type of transparent plate saves up to three months of treatment time.
3. Invisalign Lite for treating medium cases and natural bites
Invisalign Lite is a class one malocclusion treatment. These transparent plaques are mostly used in cases where a person has a normal bite, but his upper teeth are slightly ahead of the lower teeth. In other words, a mild overbite can be treated with Invisalign Lite. With this orthodontic plate, relative crowding and small distance between the teeth can be solved in these cases. This type of Invisalign uses fourteen transparent lights and movable plates (movable orthodontics) and offers a cheaper option with a shorter treatment period than other methods.
4. Full Invisalign for severe deformities
If you suffer from severe and complex orthodontic problems such as severe underbite and overbite, using Invisalign Full is a good option to solve your problem. This type of Invisalign is one of the experimental treatments dental professionals perform.
Your issue can be resolved by mass-producing the whole orthodontic plate in 3D. The number also depends on your treatment plan and the complexity or severity of your illness. This procedure may take between 12 and 18 months to resolve your dental problem.
